unlock button on passenger side not working
Old Apr 9, 2005 | 11:41 AM
TransAmMan85's Avatar
Car: 1979, 1985, 1997 Trans Ams
Engine: 455,350,350
the power door lock buttons on the drivers side work fine. on the passenger side the lock button works but when you press the unlock button it does nothing. no movement or sound. i took both buttons out and compared the metal prongs and they looked the same on both, no corrosion. i switch the buttons on the doors and now it does the same thing on the drivers door, it wont unlock it. i guess its a bad button? is there anything i can do to fix it without buying a new button? thanks for the help
Old May 25, 2005 | 02:55 PM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Can you take the button apart? I had the same problem on my 96 Grand Prix. I took the button itself apart *VERY CAREFULLY*, and cleaned the contacts w/ 91% rubbing alcohol. Worked like a charm.
Ikes 91Z
Dec 9, 2015 03:49 PM
LittleFranks
Aug 20, 2015 03:55 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
