No parking lights or tail lamps
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Ive had a problems with the front left turn signal not working for a bit, and i moved some wires around and it worked for a while. But now I was putting in my parking lamp housing, and, now they dont light up when the lights are on, the right turn signal works, but the left does nothing, so i have no parking lamps or left turn signal.
At the same time, the insturment lamps went out, and taillights, have brake lights and a right turn signal back there, but the left stays lit up when i have the left turn signal on.
Any info on this, wiring diagrahm.
Kevin
edit: this is on the 84 z28
Kevin
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
I experienced the exact symptoms last year. Mine turned out to be a shorted wire going to the license plate light. The wires looked like a rats nest back there. Nail down the circuit in a Haynes or Chiltons and check all the wires, it should be an easy fix when you find it. Good luck!
Engine: 383, L69
Yes I recieved it, Trickster, and its greatly appreciated. Ill start going over my wiring and see whats up with this crap
Kevin
Kevin
