Amp size for battery
Old Apr 11, 2005 | 11:14 AM
<<K-O>>'s Avatar
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
I'm going to replace the battery in my car It currently has a 70amp battery, I'm going to put in a hypertech coil soon and Install some high-watt audio equipment on my car in the near future.
My questions are ;
1- Can anyone tell me the original amp rate of the battery that came with 88 gta's?
2- I'm thinking of putting in a 90 or 115 amp battery in my car, my friends told me If I put in a battery more than the car can handle it could screw up my electronics. Is that true? I have a 105amp Alternator. Would 115amp battery be a problem for my car or a 90 amp?
3- Anyone know what is the biggest size battery that can fit into the original location (I also have a summit box so I'm thinking of Installing it into the trunk rather than the original location)
Old Apr 11, 2005 | 01:21 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello << K-O >>,
Your battery would not be rated at 75 AMPS. It would be rated in Cranking AMPS (CA) & Cold Cranking AMPS (CCA) both of which are in the several hundred AMP range. There were several batteries that came in the 1988 firebirds depending on the engine. They had a range of 525 CCA to 630 CCA and a load test of 260 to 310 AMPS depending on the battery and engine.
For your car with the LB9 engine, it came with a battery that had a CCA range of 525 to 570. The load test range was 260 to 280 AMPS.
Old Apr 12, 2005 | 06:03 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Actually most auto batteries are rated in Amp/Hours, the standard size for a thirdgen is a 75A/H battery. CCA and Load test ratings are the maximum current ratings that can be drawn from the battery for a given short period of time before the battery is internally damaged from the high current being drawn. AC Delco has an 85A/H battery that should fit with a 995 CCA rating for a little over 90 bucks. It's well worth it if you plan a a bigger stereo. You will not have a problem with the gen or electronics with a larger battery, the stock 105 gen will keep it maintained. Remember the gen only keeps the battery at about 75% or so of rated capacity. It's always a good idea to trickle charge the battery once a month, you will be surprised at how much longer that battery will last.
Old Apr 12, 2005 | 07:10 AM
<<K-O>>'s Avatar
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
Thanks for the answers I have another newbie question ,
Danno what is a trickle charge? How can I do it?
HP52TA
Feb 3, 2018 10:51 PM
Linson
Sep 21, 2015 01:08 PM
timonator
Sep 10, 2015 07:55 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Formula_88AE
Sep 3, 2015 01:47 PM
