Oil Pressure sensor wiring
Old Apr 12, 2005 | 05:55 PM
87TransAMTPI's Avatar
Car: 87 Trans Am
I'm in the process of swapping a out a 305 TPI for a carb'd 400 in an 87 T/A and am trying to eliminate all the wires I don't need, I found a white wire which I believe is the wire for the oil pressure sensor but then it runs into a plug that also has a green wire coming into it and then the green wire runs back through the wiring harness, Will I just need to cut the plug off and splice the white and green wires together??
thanks for any help
Old Apr 15, 2005 | 06:21 AM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
just curious, is this your first time wiring a swapped motor?
Old Apr 15, 2005 | 06:26 AM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
i would reccommend cutting anything, i would hook everything up like you were putting the LO3 back in then go from there once you get it running, alls i no is that i tried doing my wiring before i knew exactly wat i was doing and i ended up needing a new wiring harness. i would just make sure you know what is whhat before splicing/cutting. i know that the wires get annoying/frustratiing/tedious, but just take your time with it. as for the white and green wires, ill check today in my service manual
Old Apr 15, 2005 | 02:01 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Oil Pressure sensor wiring
thanks for any help
It is relativly easy. There are three wires going into the sensor. One is an orange power wire, a grey output power wire, and a white wire for the gauge.
The best and easiest way I can think to do it is to wire a 12V switched to the power wire, leave the wire going into the C100 bulkhead connector and then cut the wire for power out, unless you have an odd use for it.
89GTAOz
May 16, 2020 09:31 AM
9192camaro
16
Feb 3, 2019 12:21 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
