Recognize these?
Old Apr 13, 2005 | 08:26 PM
cryptic's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6
Transmission: TH700?
Recognize these?
I noticed these to wires kind of hanging out there. I dont think they go to anything important but wanted to see if anyone recognized them just in case. I found them when replacing the fan relay. they may go to some option the car never came with, maybe :-/
Old Apr 13, 2005 | 08:35 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Not too sure of the white one because of the cropped size of the picture. But if that is on your 90 camaro, the red wire is the fuel pump diagnostic point.
Old Apr 14, 2005 | 05:29 PM
cryptic's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6
Thank ya sir, it is a 90 RS, I have another pic of the whit one. I figured it may be another diag connection or for an option that didnt come on the car. I just dont liek to see wires that arent connected.
Old Apr 15, 2005 | 02:06 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Maybe for the brakes master cylinder to tell you when you have zero pressure. Whre does it go on the bulkhead connector, high low left right?
Old Apr 15, 2005 | 02:13 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Without seeing a bigger picture of that white wire it is hard to tell, but it is possible that it is for the tachometer from the ignition coil.
Old Apr 15, 2005 | 09:34 PM
cryptic's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6
Ok, I'll try to post a larger pic without slamming the bandwidth. The tach theory seems possible because right now my tach kind of floats around. I mean it will go up as you rev the engine but when doing 30-40MPH the tach reads about 8000 rpm.
But this wire resides by the brake booster
TheJoeY88
Dec 31, 2016 07:30 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Manic Z
Theoretical and Street Racing
Jan 7, 2003 01:33 AM
BobMachus
Apr 19, 2002 11:28 AM
Coxy
Apr 8, 2002 11:46 PM
