Jumped S terminal and power on starter and nothing happened
Old Apr 16, 2005 | 03:40 PM
stiers's Avatar
Background: Engine doesn't turn over when you turn the key to start. Power accessories work when it is on run, lights and horn work. Lights stay on when you turn it to start and do not noticably dim. 12V is present at the solenoid and the ground to the chassis as well as the starter frame is good. I jumped the S terminal and power on the starter with some needle nosed pliars and nothing happened but a few sparks, starter didn't make any noise. Guessing I need to replace the starter, I did it with the ignition in the off position, does that matter?
Old Apr 16, 2005 | 08:04 PM
stiers's Avatar
Update: I used a piece of wire to keep the ignition in the start position and went under the car to measure the S terminal voltage, there was none there on the bolt. Went to the neutral/park switch, Yellow from ignition has 12V, purple has 11V. Is there anywhere else that purple wire goes except to the starter?
Old Apr 16, 2005 | 10:51 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Don't look now, but you have a package in your e-mail.
Old Apr 16, 2005 | 10:54 PM
stiers's Avatar
Thanks! So there isn't anything in between...I must have a pinched/cut/burnt wire somewhere or I got a bad reading because it was dirty.
Old Apr 16, 2005 | 11:14 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
On the VIN "H" model there is a 3 AMP crank fuse that the purple wire also went to.
Old Apr 16, 2005 | 11:42 PM
stiers's Avatar
Vin 8 here. I went through and found where the wire came out at the bulkhead, it has 12V at start there. Found it at the alternator and it was good there...went back down to the starter and it was good there. WTF, I checked it 5 times down there before and there was nothing. So in the processes of hunting the wire down I must have moved the wire so that it works again...how am I ever going to find the problem?
I will hook the starter back up tommorow and see if it fires.
Old Apr 16, 2005 | 11:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Patience and perserverance young Grasshopper!!!!!!!!!!!!
Old Apr 16, 2005 | 11:51 PM
stiers's Avatar
I suppose I could take the purple wire and pull it out of the loom all the way back to the bulkhead and replace it.
Old Apr 17, 2005 | 12:14 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You could but I think that about halfway through you would be thinking to yourself "Why did I do this?". Have you tried starting the car with the shifter in the "neutral position"?
Old Apr 17, 2005 | 12:39 AM
stiers's Avatar
Yep, tried that before the tow truck came. Didn't work.
Old Apr 17, 2005 | 09:47 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
After doing some more reading of the schematic, I have found that purple wire does go to the 3 AMP Crank fuse that I mentioned earlier as well on your car. There is also a splice in that purple wire in the wire bundle above the right valve cover. This bundle is the one that runs across the top of the valve cover and also has the wires for the injectors in the wire loom.
BRoss99
Aug 10, 2025 05:08 PM
Infested
May 22, 2018 11:56 PM
L98GTA87
Aug 25, 2015 02:23 PM
Accerrito22
Aug 23, 2015 07:22 PM
