No Accy but it cranks
Old Apr 16, 2005 | 11:31 PM
JaizRed's Avatar
Car: '83 Camaro Berli | '86 T/A WS6
Engine: 5.7L | 5.0L
Transmission: TH-700R4 | TH-700R4
Axle/Gears: 3.08 Drum | 2.73 Disc
Car is a '85 Trans Am, 350, 5 spd. Woman's son put new alternator on it Wednesday, and for some reason decided to mess with the starter and grounded it out with a screwdriver. Since then, no accessories, no power to the dash, but the lights work and it will crank and start but only while the key is in the crank position. Power seats only work in crank position also. Purple and yellow wires under dash should be hooked into the fuse panel somewhere but I don't know -where-, but I do know that without them being stuck in a terminal, it won't even crank. Any suggestions?
Old Apr 16, 2005 | 11:46 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That purple and yellow wire that is under the dash will go to the "Clutch Start Switch" on the clutch.
Old Apr 17, 2005 | 12:04 AM
JaizRed's Avatar
Engine: 5.7L | 5.0L
Ok, so both of them go to the clutch switch behind the pedal? What about the no power issue? I don't know if the wires were hooked up any kind of way before I looked at it, but like I said, without the wires hooked into one of the terminals, it does nothing at all. And if you plug them into the terminal next to the other, when you turn the key 'on' the starter just spins. I'm pretty stumped
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
anesthes
Sep 30, 2015 07:48 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
