Alarm Installation
Old Apr 19, 2005 | 03:41 AM
Nemesis's Avatar
Car: Modified 83 Berlinetta
Engine: 350 - 300hp
Alarm Installation
Hi all,
Just got an alarm to install in my 83 and have some questions.
Will I need to get a central locking kit to get the alarm to unlock the car (keyless entry)?
Also any useful install sites I can check out?
Thanx.
Old Apr 20, 2005 | 06:27 AM
jetucker00's Avatar
Car: 89 Iroc Vert
Engine: A Loud one!
Transmission: Probuilt 700R4
As long as you currently have power locks, you can use your alarm to lock and unlock your doors. You will just have to use a relay to amplify the alarm output triggers for the lock and unlock circuits.
Here is a good site to brush up on your wiring skills before starting the project:
www.the12volt.com
and here is your vehicle wiring diagram:
1982-87 Chevrolet Camaro Security Information
Constant 12V+ Red Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Accessory Orange Ignition Switch Harness
Tach White Or Purple/White at Coil
Brake Switch White or Light Blue Brake Switch
Trunk Pin Black/Orange (-) Cargo Light
Parking Lights Brown Light Switch or above Driver's Kick Panel
Head Lamp Yellow Light Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger White (-) Driver's Pin Switch
Door Lock Light Blue Driver's Kick Panel
Door Unlock Black Positive Trigger
Horn Wire Black (-) Steering Column
Pm my or post any questions and I will see if I can help you out.
Good luck!
Tuck
Old Apr 23, 2005 | 07:41 PM
Nemesis's Avatar
Engine: 350 - 300hp
Cheers
Thanks Tuck,
I will check the site out and PM you if I get stumped.
Nem
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
Stauf
Aug 24, 2015 08:31 PM
