Headlight Relay? 83 Camaro
Old Apr 21, 2005 | 07:48 PM
MADMANAMI's Avatar
Car: 83 BERLINETTA
Engine: 350 4 BOLT MAIN
DOES ANYONE KNOW WHERE THE HEADLIGHT RELAY IS ON A 83 CAMARO?
Old Apr 21, 2005 | 09:22 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you are referring to the berlinetta version of the camaro that you have listed in your profile. The headlight relay is located in what is called the light module. It is located behind the right hand side of the instrument panel behind the Electronic Center Module. BTW, as a side note here. In the future when posting on this board, please refrain from using all upper case letters when posting. Lower case letters are more desirable here. THX!!!!!!!!!
Old Apr 21, 2005 | 09:56 PM
MADMANAMI's Avatar
Car: 83 BERLINETTA
Thanx so much for the reply, sorry about the "caps" !!! I'll take a look at it.
Old Apr 22, 2005 | 12:55 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
yea no yelling in the boards
Old Apr 24, 2005 | 03:20 PM
MADMANAMI's Avatar
Car: 83 BERLINETTA
My 83 berlinetta doesn't have the light module (LM) you're talking about. I already took the ECM out of the car and the LM wasn't attached to it. I also have an 84 that i use as parts and it has the LM so i'm still stumped. thanx anyway
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Zachattack0925
Aug 12, 2015 09:52 PM
