vats resistance
Old Apr 22, 2005 | 09:40 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
vats resistance
I found a decoder box for my 91 harness, but how do I figure out what resistance to use to fool the vats now ..... does any numbers on the decoder box tell what resistance to use.
Old Apr 22, 2005 | 10:02 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No, there are no numbers on the decoder box to let you know what the resistance value is. The reason for this is that they are all blank until the first time the car is started with a coded key. That resistance value is then permanently encoded into it and cannot be changed. You might be able to take it to a dealership and let them try to read the encoded resistance value or go to a locksmith that has that capability.
Old Apr 22, 2005 | 10:55 PM
Jproz1167's Avatar
ok let me ask you this .... my ecm isnt vats enabled, will the car crank with the starter enable relay hooked up or can all the vats stuff be just left unplugged and the car will start.
Old Apr 22, 2005 | 11:00 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If the car does not have a computer that has the vats capability you can bypass the starter enable relay by splicing the wires at pin "A" & "E" together. The vats control module does not even have to be installed.
Old Apr 25, 2005 | 12:17 AM
Jproz1167's Avatar
trickster
on a 89 vats decoder there is a green wire, where does it go, on my 90-92 harness where the 89's green wire is there is a black wire with yellow strip, my 89 vats decoder wont plug into this 90-92 harness aside from the color differences I thought I would just change the plug,.
so does this black wire with yellow stripe go to the same place the 89's green wire does aside from this all the wires are in the same place and are the same color.
also whats the difference between a 89 tbi ecm and a 90-92 tbi ecm and ecm harness.
thanks
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
AmorgetRS
Sep 28, 2015 09:33 PM
Winchester1094
Sep 15, 2015 09:48 AM
