Electric Fan
Old Apr 26, 2005 | 09:11 PM
POS Camaro's Avatar
Car: 1986 Camaro Z28
Axle/Gears: 3.73 Posi
Electric Fan
I have an '86 Camaro Z28 that I think came stock with an electric fan. Right now the fan is always energized with the key in 'ON'. I pulled the diagram and it looks to be a simple electrical setup. If anyone has ideas other than the coolant fan switch or the fan relay, speak up. I would appreciate it if someone could tell me where those 2 items are located. The computer doesn't have anything to do with energizing the fan, does it?
Attached Thumbnails Electric Fan-electric-fan-86-camaro
Old Apr 26, 2005 | 09:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Is that the original engine in your car and is it the fuel injected model or the carburated model. The schematic that you have shown there is for the carburated model.
Old Apr 27, 2005 | 06:42 AM
POS Camaro's Avatar
It is now a 350, stock was a 305. It is a VIN H car. I've got a lot of work to do to make the car emissions legal.
Old Apr 27, 2005 | 07:27 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Fan switch is in pass side cyl head, relay on firewall by brake booster. The computer doesn't turn on the fan, but the A/C does. You should be able to figure it out with the diagram you have.
Old Apr 27, 2005 | 12:20 PM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
on my 86 TPI the relay is right by the battery. very close to the fan so the high amp travels a shorter distance. and the temp switch for the ECM is in the front middle of the intake manifold.
this is for my single fan 86 IROC tho, possibly the relay may be in a different spot but that sensor will still be in the manifold. the senser in the driver head goes to the guage in the dash
Old Apr 27, 2005 | 12:44 PM
Lo-tec's Avatar
Incorrect. The temp switch is in the pass side cylinder head.
POS Camaro, if you have the whole manual, look near the section where the picture you posted is located. There is a component locator in there that might help finding the relay.
Old Apr 27, 2005 | 03:08 PM
Engine: 305ci TPI
ohh, actually the driver side head does go to the guage but thats not what was being talked about, i wasn thinking right. your right about the sensor in the pass head
Old Apr 27, 2005 | 08:11 PM
POS Camaro's Avatar
Right now there is no sensor in the passenger head in the front portion. I don't have the complete '86 book, just the prints from the 'net. I do have the book for the '85, is that the same? I'm thinking that I need the temperature sensor and the relay.
Old Apr 27, 2005 | 08:18 PM
Lo-tec's Avatar
Sensor is on pass side between exhaust ports on cyl's 6 & 8. I think the wiring is the same, look to see if the picture in your 85 book looks like the one posted (this all looks the same as my 84). Try and figure out why it is always running (or if someone hacked it to do so) before just replacing parts.
sheachopper
Jul 31, 2019 11:27 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
