Fuel Pump Wiring
Old May 1, 2005 | 09:58 PM
stenseltizm's Avatar
Car: 89 RS
Engine: 400 sb
Fuel Pump Wiring
I know i've seen this in another thread, but my search turned nothing up. where do the wires run to the fuel pump in the tank? I went to carb with a mechanical fuel pump, but havn't dropped the tank yet. I need to drain the tank, and figured i'd hotwire the electric pump to drain it. Any other easier ways or locations of the wires to bug into? thanks
Old May 1, 2005 | 11:01 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Well if you haven't removed the wiring for the fuel pump relay, you can apply 12 volts DC (+) to pin "A" of the connector and a good ground to run the fuel pump to empty the tank.
Old May 2, 2005 | 12:16 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
can supply a pic of the fuel pump connnector/term? and how do i go about draining the tank once the car is lifted? thanks
Old May 2, 2005 | 01:04 PM
Car: 89 RS
Engine: 400 sb
The The Relay for the fuel pump is long gone, but i don't remember if the wires have been removed yet. If I go that route, where do I need to hook up a 'good ground'. If the wires by the firewall are already gone, i'll have to bug into the wires near the tank. Do these run under the car or under the carpet?
Old May 2, 2005 | 01:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You can just ground it to the car frame or the engine it self.
The wires run from the connector behind the rear seat along the drivers side of the car underneath the carpet and door sill.
Old May 2, 2005 | 06:39 PM
Car: 89 RS
Engine: 400 sb
Is fuel supposed to be **** orange? jk thanks alot trickster
Old May 2, 2005 | 09:25 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Fuel that has a little age to it will be some what of a darker color where it starts to break down. It probably also has some rust in it.
Old May 2, 2005 | 10:56 PM
Car: 89 RS
Engine: 400 sb
Yeah, that was a joke. The fuel is like 3+ years old, I never even thought about it when I did my swap until I couldn't start it this spring. I can't believe I even got it running last year. Does fuel like that mess up the carb? I remember hearing something about fuel varnishing parts of the carb or something when I was younger.
Old May 2, 2005 | 11:42 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes fuel tends to leave a varnish in the carburator and other components over a period of time. When I was running a carb in my 85 Z28 I would take and spray some carb cleaner in the carb about once every two months to sort of clean it out some. It doesn't actually mess up the carb per se, but over a period of time it will start to build up and restrict the flow of fuel in the lines and jets on a carb and fuel injectors.
Old May 5, 2005 | 08:20 AM
knhghs's Avatar
Fuel gauge sender diagram needed.
My fuel gauge is now reading way past full. I assume the sender wiring is screwed up somewhere. There are 3 wires coming out of the sender. Black=ground Pink=sender to gauge Question is, where does the tan wire go?
Old May 5, 2005 | 08:42 AM
Car: 89 RS
Engine: 400 sb
Black = Ground
Tan = 12 volts - 12 Volt Fuel Pump Source
Red = 5.3 volts - Fuel Gauge Voltage will vary with level
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
