Can I use neg. to trigger the relay
Old May 2, 2005 | 09:52 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I am needing a relay to provide ground all the time until relay is activated and then ground removed when I flip a toggle switch. I know this sounds weird but this is what I need. The relay has 5 pins. Is there a way to just use a negative pulse on the input side and output side but use a positive to trigger the relay. I'm thinking that I need to use the normally closed pin and then just let it open. Is this anywhere near right?
Old May 3, 2005 | 02:50 AM
Javelin3o4's Avatar
Car: 1971 Camaro
Transmission: TH350
what is the relay gonna be used for?
Old May 3, 2005 | 07:03 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
go to www.the12volt.com they have relay schematics for every type of configuration....
Old May 3, 2005 | 07:08 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
If you have a switch or an alarm or keyless entry that has a negative output that you wish to use to switch a device that requires 12V+ such as a horn, dome light, parking lights, head lights, hatch release, etc., wire a relay as shown below to convert the negative output (trigger) to a positive output.
Old May 3, 2005 | 07:09 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
If you have a switch or an alarm or keyless entry that has a positive output that you wish to use to switch a device that requires a ground such as a horn, dome light, parking lights, head lights, hatch release, etc., wire a relay as shown below to convert the positive output (trigger) to a negative output.
Old May 3, 2005 | 07:20 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
thats the just a few of the relay schematics... good luck
Old May 3, 2005 | 05:30 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Thanks guys. I think that the second diagram will work for what I'm doing. I'll post the results and what I'm building when I get this thing done. Thanks again Will.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
