Electrical system not working help please
Old May 5, 2005 | 11:34 AM
reaper317's Avatar
Car: 89 camaro
Engine: 305 tbi :(
Transmission: stock....duno...auto
I need help with my car. Recently the electrical system has stoped completly. The headlights/fan/ignition/and starter still work. thats it. nothing else will work. nothing inside the car. The fuel pump doesnt work so i cant start it. I had it fixed once and it did it again about a month or two later. When it was fixed i was told i need a new computer that it was going out and this sorta thing could and probably would happen again. Well it did. So i was wondering if any of you guys had these symptoms and knew if it really was the computer and if it is could you tell me where it is located on the car? Also would it be too hard to replace myself? thanks in advance
Old May 5, 2005 | 12:03 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
your computer will not cause a complete sys power failure, maybe a dead batt or burnt out fusible links will... or brkn conn from batt to car..... maybe trick or someone will explain it better, good luck!
Old May 5, 2005 | 04:41 PM
reaper317's Avatar
Car: 89 camaro
Engine: 305 tbi :(
well ive discovered that it seems to have knocked out the things conected to the fuse box only..... unless the headlights have a fuse in there i have not found......but all the fuses work.......so im wondering if the fuse box is not getting power from somewhere....do you know if it is conected to the computer somewhere down the line?
Old May 5, 2005 | 04:45 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i bet its a fusable link blown or defective...... or one of your batt cables is not connected..... your fusable links are accessed from under the car from what i hear near the batt
Old May 5, 2005 | 10:15 PM
reaper317's Avatar
Car: 89 camaro
Engine: 305 tbi :(
well the guy who had fixed it tempararly said he will come by to look at it but now thinks its a cable from the starter or a blown circute..... i told him that it seems that only things conected to the fuse box dont work........soooo ill find out tomarow when he stops by to check it out. i hope it dont cost to much though cuz i dont have any extra ca$h
Old May 5, 2005 | 10:46 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Take matters into your own hands and get a schematic. Once you have a schematic you can trace down the problem yourself and fix it, or take it somewhere and tell them what is wrong instead of them bumbling around your car. The fuse box supplies power to the ECM not the other way around.
Old May 5, 2005 | 10:49 PM
reaper317's Avatar
Car: 89 camaro
Engine: 305 tbi :(
ok im retarded......the ecm is the computer? so it could just be the wires going to the computer? and it will get done faster if i let the other guy fix it. i hope.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
lakeffect2
Aug 23, 2015 08:44 AM
