How could i get the trunk open without having it wired up
Old May 7, 2005 | 10:54 PM
KillerRS's Avatar
I previously pulled the wring harness out of the engine bay because im redoing the entire wiring system. Now how would i go about getting the trunk open? does anyone have a wiring diagram? thanks
Old May 8, 2005 | 07:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Key?
JamesC
Old May 8, 2005 | 08:48 AM
Meatwad's Avatar
On Probation
Car: 1987 IROC
Engine: 350?
Transmission: 700-R4
Originally posted by JamesC
Key?
JamesC
Something was wrong with my trunk lid, I hit it onetime instead of the windows, sucker came loose at 70mph DOH
Old May 8, 2005 | 10:09 AM
KillerRS's Avatar
Key?
JamesC
Yeah thats anouther problem, i dont have a key, well i have half a key. Isnt there a way to wire up the switch to a 12 volt power source and make it so the trunk will open like its suposed to?
Old May 8, 2005 | 05:35 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
sounds like your drilling a lock or having a locksmith come open it if you already have the entire harness out. cause i dont know about you but laying the backseat down and laying back there trying to get the cover off to the hatch latch wouldn't be fun also unless the 2 screw are out of the top i think your going to have to break he back plastic panel to do it this way. But if the harness is still in the car you should be alright, i think there should be either an orange wire OR a red/white wire i think the red/white wire is for the release pull down. so if you give them 12 volts you should be all right
Old May 8, 2005 | 07:25 PM
KillerRS's Avatar
Just the engine bay harness is out, Im gonna get the wiring diagram off the computers at school tommorow and jerry rig something up, or at least give it a shot. IM also gonna stop by the dealership and see if they hopefully still have the codes for the keys, i know its 15 years old but they had them 2-3 years ago
Old May 9, 2005 | 02:07 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
just run a jumper wire to a BAT or ignition terminal on your fuse box and hit the switch and it should open
Old May 9, 2005 | 04:08 PM
KillerRS's Avatar
I got the trunk open (went to the dealer and got a key) but now i cant close it :hmm:
Old May 9, 2005 | 08:24 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You have to have power to the hatch motor for it to close.
Street Lethal
Apr 30, 2019 12:14 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
Jae992
Aug 27, 2015 09:07 AM
Dialed_In
Aug 20, 2015 01:45 PM
mx127
Aug 10, 2015 08:13 AM
