Computer port, where is it.
Old May 17, 2005 | 06:11 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
I'm confused as to where my computer port is or where it should be. Here is a photo where I believe the port should be. If not, where is it. I have an '82 Firebird.
Old May 17, 2005 | 08:45 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Should be there. That is the location. I guess make sure you have a computer and then trace the wires.
Old May 17, 2005 | 01:49 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
WTF, its gone
Might want to take that lower panel off and take a look
Old May 17, 2005 | 03:55 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
I know the car has been converted to carb, but this shouldn't be a reason to hack out wiring. I hate when people do that, just leave the wiring there
Old May 29, 2005 | 03:39 PM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
Hi,
This is real funny bucause the DIAG Connector wiring is part of the dash wiring.
If you go all over this board, you will find many guys that are ripping out the computer harness and converting the car over to carb.
Now I understand that some of these cars are being used for drag racing, racing off road etc, and that OK.
But for cars that are being driven on the road, the ECM computer is our friend. The ECM/CCC maintains the proper Fual/Air ratio. timing ETC.
When I installed the TPI motor in my 82 Firebird I did not change any of the orginal wiring. Yes the original computer harness came out. The new computer harness was wired into the car at the same connector that was orginaly connected to the CCC computer for the LG4 engine. No modifacations was made to the fuse box etc.
I have not had any electical system problems with the orginal wiring to the car in 23 years of ownership. I have only one problem with wiring on the new computer harness and that was caused by the accident in 2002.
So the moral of this story is not to change the orginal wiring of the car.
86IROC112
Aug 21, 2015 07:20 PM
stalkier
Aug 21, 2015 01:54 AM
Bryan F
Aug 18, 2015 02:28 PM
Jake_92RS
Aug 11, 2015 10:39 AM
mx127
Aug 10, 2015 08:13 AM
