Help! Unknown Headlight Control Module Component!
Old May 21, 2005 | 02:15 PM
kin's87GTA's Avatar
Car: 1987 GTA
Transmission: A4...soon M5
Can anyone tell me the cross-reference number for the power transistors on the Headlight Control Module shown below. The components in question are circled in the picture. They appear to be marked with GM in-house numbers. "GI PA75N85s"
Thanks,
Matt
Attached Thumbnails Help! Unknown Headlight Control Module Component!-hcmsmall.jpg
Old May 21, 2005 | 02:28 PM
kin's87GTA's Avatar
Car: 1987 GTA
Okay, to make it small enough i just showed a picture of the component.
Thanks,
Matt
Old May 21, 2005 | 05:51 PM
kin's87GTA's Avatar
Car: 1987 GTA
...and I only think its a transistor...
Old May 25, 2005 | 05:38 PM
kin's87GTA's Avatar
Car: 1987 GTA
I suppose I'm off to the junkyard...?
Old May 26, 2005 | 12:53 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Try looking up the lower four digit number... ONLY the lower four digit number...
Old May 29, 2005 | 03:10 PM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
You also may have other problems that cause that transistor to go bad.
Old Dec 14, 2023 | 08:49 PM
Tyler327's Avatar
Car: 1989 Trans Am GTA
Engine: 383 Stroker
Transmission: TH350
Re: Help! Unknown Headlight Control Module Component!
I'm a little late to the party, but I found a what I believe is an identical part number for the transistor like component. It is a field effect transistor for switching applications and motor drivers, and it can be controlled by logic circuitry, which is why there's the 16 pin DIP IC chip in the module doing the switching. here is the mouser link! hope this helps somebody like me that's been researching forever!
https://www.mouser.com/ProductDetail/512-BUZ11_NR4941
Old Dec 14, 2023 | 09:06 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Welcome to the site. That's a neat find. Have you used it yet and did it work with your repair?
Old Dec 15, 2023 | 07:44 PM
vorteciroc's Avatar
Top Answer: 1
I can not believe how many people have never seen a M.O.S.F.E.T...
Or any type of Transistor for that matter.
Transistors Revolutionized the Modern World.
(Could you live without all of your day to day Electronics???)
M.O.S.F.E.T.s actually re-Revolutionized the Modern World!
Old Aug 18, 2025 | 09:12 AM
Tyler327's Avatar
Engine: 383 Stroker
Transmission: TH350
Yes, the MOSFET worked, but the relay is clicking but not driving the motors, i tested the entire circuit and the headlights come up when i put power to the wires themselves and power is coming from my switch so it has to be the module. I have a lot of electronic parts lying around so I tried making my own version to avoid paying for a new one and the IC i chose wasn't correct. I think i will just use an Arduino type device to control the relay and remove the IC in general.
Sorry for the super late reply, i haven't been active on here in a long time, i didn't think i would get any reply's.
Hotrodboba400
Dec 10, 2019 07:07 PM
TrevinE
Sep 14, 2015 03:20 PM
Jlanz55
Sep 6, 2015 02:35 PM
luvofjah
Sep 3, 2015 07:08 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
