Hatch Solenoid problem
Old May 22, 2005 | 09:00 PM
ThaBlur's Avatar
Car: 87 Std. Camaro
Engine: 305 4 barrel
Transmission: t-5
I just upgraded my hatch pull down motor to a pull down release motor. However getting the solenoid grounded is a nightmare.
I have been able to activate the solenoid on the front end of the car by making the solenoid touch bare metal and the tapping the release wire on the positive terminal.
I grounded the solenoid to where the pull down ground is on the car. It still doesn't work. I've tried to grind different areas across the rear of the body to make a clean surface for a ground.
Any help would be greatly appreciated.
Old May 22, 2005 | 10:02 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What year, make, & model car did you get your hatch release & pull down motor from?
Old May 23, 2005 | 08:15 PM
ThaBlur's Avatar
Car: 87 Std. Camaro
Transmission: t-5
The hatch solenoid is from an 87 trans am, and the pull down unit is from an 86 camaro. I still have the solenoid that belongs to the 86 pull down motor, and I also still have the pull down motor for the 87 solenoid.
I'm installing the motor on an 87 std camaro.
Street Lethal
Apr 30, 2019 12:14 PM
hydrolic144
Sep 8, 2015 06:55 PM
injdinjn
Aug 28, 2015 12:51 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
