tach problem
Old May 17, 2005 | 09:34 PM
TOM1960's Avatar
Car: wow thats alot of cars i own , now 1999 silverado
Engine: 4.3 v6,3-350 TPI,71CAMARO SS TPI 350,91 CAMARO RS 350 5 SPEED,86 C-10 350/TH 350C
Transmission: 3-automatics, 1- 5 SPEED
tach problem
hey guys im new so be gentle,
ok my prblem is , i have a 1991 RS camaro, 305V8, 5 speed trans , and the prblem is the tach i cannot get it to work when car starts it sweeps all the wat to the end of the guage and stops ? or dont move at all checked the connection seems good checked the coil seems gfood and connection at the coil is good? please help im not good in the electrical area of cars !
thanks tom
Old May 17, 2005 | 09:39 PM
PurpleHaze92's Avatar
Car: 1992 rs
Axle/Gears: ones that turn
Hmm tom I have the same problem on my 92 not sure yet what the problem is
Old May 17, 2005 | 09:41 PM
TOM1960's Avatar
tach problem
hey man how are ya ! ya know the car runs fine a little rich but cant get that dang tach to work? all the other guages work fine but the tach?
tom
Old May 18, 2005 | 06:47 AM
TOM1960's Avatar
tach problems
come on guys surely someone out there knows about this ????? ya all know about everything else ! please help!!!!......lol
thanks tom
Old May 18, 2005 | 11:07 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Are either of you running an MSD ignition box? Does the tach work w/o it if you are?
Old May 18, 2005 | 11:23 AM
TOM1960's Avatar
tach prolems
nope all stock car tbi 305 , 5 speed tranny , any ideas? please help if ya can remember all stock nothing added
thanks tom
Old May 18, 2005 | 11:42 AM
Car: 1992 rs
All stock here too (well its a stock '86 tpi in the 92)
Old May 20, 2005 | 10:32 AM
STRIFE69's Avatar
Car: 91 camaro
Engine: 305TBI
Transmission: 5 speed
Currently same problem here with the tach. Will post again on what I had to do when I get it fixed. Hopfully very soon!
Old May 23, 2005 | 07:37 PM
STRIFE69's Avatar
Car: 91 camaro
Engine: 305TBI
Well I got my tach working. Here is what I did...
I was lucky enough to have purchased a 92 (v6)parts car recently. I took out the whole dash cluster and plugged it into my car. I worked just fine.
So I then decided to try swapping out my tach with the one on the good cluster and it worked fine also. So I decided to put my speedo and guages in the good cluster and all works fine now.
I also tried the tach from the 92 in my original cluster and it was doing the same thing (buried). I believe the little circuit board on my cluster for the tach is bad. That or was getting some bad connection with my original cluster when plugged into the dash.
Hope this helps you on fixing your tach prob.
Old May 23, 2005 | 08:27 PM
TOM1960's Avatar
TACH PROBLEMS
HEY THANKS FOR THE INFORMATION ! I WILL TRY THAT
THANKS TOM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
