Want to add fog lights to my 91 RS Convertible
Old May 18, 2005 | 09:50 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I am trying to add factory fog lights to my 91 Camaro RS. I have located the switch plug and the relay plug, my question is where is the rest of the wiring that goes to the actual fog lights. I have done a search but when it comes to finding out where the rest of the harness is that is where the thread ends. Please help!!!
Old May 19, 2005 | 06:33 PM
AaronIROCZ's Avatar
ANYBODY????????
Old May 19, 2005 | 06:37 PM
Yossarian14's Avatar
Car: 1986 z28 and 1997 Disco
Engine: Lg4 305
Um I added them onto my car when I got my new front end and just spliced into them and connected. Drill the center hole a little bigger and stuck some blazers in there.
Old May 20, 2005 | 10:06 AM
AaronIROCZ's Avatar
Yeah but I dont have any wires to splice into, I have all the wiring on the inside just not on the outside. I really want to use the factory setup.
Old May 21, 2005 | 02:18 PM
AaronIROCZ's Avatar
Anybody else?????????????????
Old May 21, 2005 | 05:43 PM
Engine: Lg4 305
The wires come out of the wiring harness, in the left front of the car by the vacuum canister but thats on my 86.
Old May 22, 2005 | 09:22 AM
AaronIROCZ's Avatar
Yeah my 89 has the wires but the whole harness is different because of the air bag stuff. I know somebody here has to have done it, I know that I am not the only one here. Or if anybody has an idea where I need to add wires to the firewall connector. Anybody have a wiring diagram for the fog light system on a 91 Camaro.
Old May 23, 2005 | 09:28 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I need the diagram too. I got a harness but it is not for a '92. So I want to rewire around the factory setup. See my other post.
Old May 23, 2005 | 04:22 PM
Engine: Lg4 305
I got the shop manual, I'll see if I can find what you need and will post it tonight. Im happy as can be, I just hooked up my foglights which I didnt even know was possible. I bought the car without any, replace the front end with a Berlinettas (didnt know anything about camaros then replaces the front end again only to find I had everything I needed so I drilled the hole a little larger and stuff some blazers in there.
Old May 23, 2005 | 06:17 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
ok i did this on my 91 formula....
the problem was that i had all the wiring under the dash like you siad you have, but the wires were not up at the front of the car....
so coming off the relay you will see 2 purple wires that go into the same pin out on the relay. right, ok one of those goes up to the switch itself, and the other goes out to the firewall, but it ends there, so you have to cut that and run a lead out to the fog lights themselves, and then just ground them anyware. now you just need to get your switch, a relay and a fuse and your all set. when you get the fog lights, try and get the pigtails that plug into them, makes life simpilar
Old May 23, 2005 | 09:11 PM
AaronIROCZ's Avatar
THANKS you da man. That is what I need to know
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
