retro vats in 87 str. column in 91 formula
Old May 29, 2005 | 12:53 AM
firehawkslplus's Avatar
Car: 91 Firebird Dark Green
Engine: 350 Victor Jr. 2V 2000 CFM TB EFI
Transmission: 700R4 BM 2500 stall
Axle/Gears: 3.73 Zexel torque sensing Posi
I've got 91 Formula w/ VATS. Column has the wobbles; will the VATS lockcyl and it's wiring fit in an 87 formula column both are tilt?
Old May 29, 2005 | 10:10 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
don't know about the vats tumbler but the wiper switch wiring is different, so you will need to put your formulas wiper switch and wiring int the other column to
Old May 29, 2005 | 10:29 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The lock cylinder will fit although it might be a little snug, Since you don't seem to be swapping out the wiper switch it shouldn't be a problem here, but as Jproz1167 has mentioned, the wiper (multifunction lever) switch did change in 1990. The wiring became shorter among other things.
Old May 29, 2005 | 06:39 PM
I'm not clear; is it possible to put the 91 switch in the 87 column? Does it make more since to repair the 91 column. This is not a pressing problem yet, just looking gather info. never had to work on the column before. Thanks for your time and input.
djmarch
May 8, 2016 11:32 AM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Tweeks25
Sep 17, 2015 08:04 AM
Winchester1094
Sep 15, 2015 09:48 AM
383cam
Sep 9, 2015 06:01 AM
