Help No Headlights!!!!!
Old Jun 2, 2005 | 09:19 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Ok so for the past couple of years my headlights would not go down on theyre own. Then last weekend i picked up a used headlight switch and replaced mine and wha la they worked. Well 2 nights ago i was driving at night i shut off the car for about 10 minutes and came back and the headlights would not come on, nore would the dome light, parking lights ect. I tried to put the old switch back in with no change. Someone please set me in the right direction here.
Old Jun 2, 2005 | 11:00 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Anybody?
Old Jun 2, 2005 | 11:09 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Check all the fuses?
Old Jun 2, 2005 | 11:12 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Yep, all fuses good
Old Jun 2, 2005 | 03:23 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
ttt
Old Jun 2, 2005 | 04:01 PM
wrightz28's Avatar
Car: '88 GTA,'85 z28
Engine: L98, LB9
Transmission: 700 r4
Axle/Gears: sleepy 3.23, hello 3.73
Sounds like you have an open circuit, most likely on the power or ground side. I'd start with the power side @ the switch and see if you have any juice coming in.
Old Jun 2, 2005 | 04:52 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Its kinda hard to figure out whats what because the headlight doors are controlled with the switch as well does anyone have a diagram for the wiring.
Old Jun 2, 2005 | 05:50 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
UH_HUH, check your e-mail!!!!!!!!!
Old Jun 3, 2005 | 09:13 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Hey thanks a lot , i appreciate it. Ill dig into her again tonight and see what i can find.
Old Jun 3, 2005 | 09:48 AM
shuf's Avatar
Car: '89 Firebird Formula R.I.P.
Hey I was wondeirng if you could email me those diagrams, I am having a problem with my headlights too (shuf@umich.edu).
Old Jun 3, 2005 | 10:17 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Check your email.
Old Jun 3, 2005 | 10:26 AM
shuf's Avatar
Old Jun 4, 2005 | 08:17 PM
x007's Avatar
Car: Supercharged Nitrous T/A
Engine: Motown 410SBC
Transmission: 4L80 - Compushift / Custom billet torq
Axle/Gears: 12b Moser 33/spl. /373 posi
can you email me the diagram troo plz..
thanks..
transam@techbull.com
Old Jun 4, 2005 | 09:27 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
thanks..
What year & model is your car?
Old Jun 4, 2005 | 11:14 PM
x007's Avatar
84 trans-am
actualy i'm able to open the headligt but they dont want to close anymore.. I think i have the wrong relay somewhere, i have 3 relay, 3 wire motor (and over 6 relay on hand whit diff. # but all whit the same connection... whats a pain in the ***...)
So actualy i'm going a wire inside of the car whit a pushbutton to give + on the darkblue/darkblue white wire to close the headligt.. I can open whit the switch but have to give + at those wire to close it... (the light itself is going off ok)..
Old Jun 5, 2005 | 04:37 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Trickster, Can you send me one too. 86TA. thanks
Old Jun 6, 2005 | 01:14 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Ok so no luck fixing yet, here are the current simptoms to the problem. The headlights,marker lights, interior lights, dash lights,power locks, and rear hatch have no power. But yesterday i hit the power locks and they worked a few times, so i hit the light switch with the car off and i heard the tone for a second then nothing the lights didnt come on but where about to. Then i hit the locks and they didnt work again. Any suggestions or more detailed diagrams or pictures would be appreciated.
Old Jun 6, 2005 | 11:05 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
desperate here have tried to search several times and have found some info, but not much. Has anyone else had this problem????
Old Jun 6, 2005 | 11:15 AM
shuf's Avatar
84 trans-am
I had this same problem. I got a new headlight switch from autozone, pn: SW235, and it fixed it.
Old Jun 6, 2005 | 11:31 AM
Wayne's 383Iroc's Avatar
Car: 88 IROC
Engine: 383
On my 88 Iroc there was a bad conection in the box going through the firewall. The weather sealent had got hot and run down on the contacts. It took a long time to figure it out. I had no power to the light switch or dome lights.
Old Jun 6, 2005 | 03:48 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
New update car sat overnight last night with the headlight switch in the on position, today the headlights were up but not on. Im starting to think its a bad ground i just cant find it. Im gonna take off the kick panel and dig around tonight.
Old Jun 7, 2005 | 09:31 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Its fixed, I was diggin around last night, got down by the starter and started playing with the wires attached to the starter and at last success. The wires had some corrosion around them and it looks like they didnt have the greatest connection. Thanks a lot for the help guys. To all the unanswered old dead posts about similar problems here is your solution at last.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
