switching to delay wipers
Old Jun 3, 2005 | 06:22 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
i am getting a new steering column and it has delay on the switch. will i need a new motor since mine currently does not? i cant imagine i would.
Old Jun 3, 2005 | 10:06 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It isn't the motor that you would have to replace, it is the circuit board inside the motor case.
Old Jun 5, 2005 | 05:37 PM
drdave88's Avatar
Engine: 6.0L
well i guess ill be getting a new motor then, lol. probably time for one anyway, its only got a ton of miles if its the original one anyway.
Old Jun 10, 2005 | 07:18 PM
allegam's Avatar
Car: 84Z28
Engine: 305 HO
I have installed delay wipers in every car I own (from 84 up to a 98, so I cannot vouch for any years newer).
It takes 3 defined items:
1: Delay wiper switch in column, in thirdgens you will have to run wires down the column to install, newer cars the wiring plugs into the switch at the top making it a plug and play affair with no wire routing.
2. Delay wiper stalk
3. Wiper motor cover that has a circuit board in it. I walked around a few junk yards until I saw a car with delay wipers and an uncracked plastic cover. Undo the torx screws on the top of the wiper motor and grab the black plastic cover.
Install the cover on your car and install the proper stalk and you are set to go.
wigmobile
Feb 26, 2025 02:56 PM
corey8084
Sep 17, 2015 02:56 PM
Randomtask2
Sep 10, 2015 08:37 AM
adelane
Sep 9, 2015 08:51 PM
scottmoyer
Sep 7, 2015 07:06 PM
