funky electrical problems
Old Jun 4, 2005 | 07:29 PM
VroomVroom87Z28's Avatar
Car: 87 Z-28
Engine: 305 ci. LB9
Wow, it seems like it's just one thing after another with this car, one day it all run like it should. Anyway, I have a few electrical problems and was wondering if anyone had similar ones or new how to fix these. First, when the headlights are on the left signal doesnt work, not like it should anyway. It blinks about once every three seconds, and when its off the left signal indicator on the dash is slightly glowing but outside it's off. Again this is only when the headlights are on, when off it works fine. Second is my pull down motor, sometimes it goes when you hit the switch sometimes it doesn't...it's moody. And when I have to use the key the hatch will unlock but sometimes the motor won't come up. And I guess that's all for now, any help would be much appreciated.
Old Jun 5, 2005 | 08:01 PM
Vader's Avatar
I'd wager two of your favorite beverages that you're going to find a problem with a ground connection somewhere. Start up front, on the radiator support and inner fenders.
customblackbird
Aug 15, 2021 10:16 PM
Cornholio7979
Sep 20, 2018 02:31 AM
toones
Jan 6, 2016 06:00 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
