air/fuel o2 wire problem
Old Jun 8, 2005 | 12:20 PM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
I got a splice tap and put it on the O2 lead on the O2 side of the connector (not harness side). My friend did the same on his Ford Ranger and it worked fine.
I got in he car started it up with nothing on the other end of the wire. As soon as I check it with a digital volt meter, WinALDL shows the O2 dropping to below 0.2V. Heck, if I touch the thing with my figner it drops to below 0.2V. I also tried the gauge just for kicks and the same thing happens.
I check the wire's resistance and it is 1.7 ohms with both an unused splice connector and the spade attached.
What did I do wrong here? Should I spend the entire day tearing apart the dash to hook it to the ECM? I'd rather not hack into the harness if possible.
Old Jun 9, 2005 | 07:58 PM
MechCD's Avatar
Engine: LO3, Vulcan
It doesn't show anything when its not in "run". I think i managed to mess up one wire
Using the battery as the ground for the DVM, shouldn't it have voltage on it all the time?
BahamutRS
Sep 23, 2001 10:12 PM
FastElectrics
Aug 3, 2001 12:23 PM
BahamutRS
Jul 22, 2001 06:50 PM
theformula
Dec 15, 2000 08:13 PM
Z28HO
Carburetors
Oct 5, 2000 02:58 PM
