Fuel Gage Wiring Route
Old Jun 8, 2005 | 07:47 PM
Cabbie's Avatar
Could anyone tell me where the fuel gage wiring routes to after it goes behind the rear seat? Does it go along the center console or along the driver’s side door? My gage reads full all the time. I've checked the wiring continuity from the tank to behind the seat. It has no shorts there so I'm working forward. Thanks
Old Jun 8, 2005 | 08:37 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
After coming from behind the rear seat, it turns toward the driver side and follows along the door frame under the black doorgaurd edge. AFAIK it will be a pink wire that goes all the way to the dash wiring.
Old Jun 12, 2005 | 01:59 PM
cuda71ss's Avatar
Car: 1986 Chevy Camaro
Engine: 5.7L 350
Hey, I'm having , at least it sounds like, the same problem. Does the pink wire running back from the instrument cluster go straight to the connector in the back seat? How many volts should it get? I'm so confused.
Old Jun 12, 2005 | 02:01 PM
Klortho's Avatar
Car: 1987 GTA
The pink wire runs from the cluster to a set of plugs behind the driver kick panel, these plugs are for the taillights, brake lights, etc etc plus the fuel pump wiring and sending unit. AFAIK there is not any voltage, but a resistance from the sending unit that moves the fuel gauge.
Old Jun 12, 2005 | 02:04 PM
cuda71ss's Avatar
Engine: 5.7L 350
Ok, at the 3- wire connector in the back seat, there is a black, pink, and it looks to be like tan wires for a ground, fuel gauge, and fuel pump right?
Old Jun 12, 2005 | 02:42 PM
Klortho's Avatar
Car: 1987 GTA
That would be correct.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
Irocohio
Aug 12, 2015 08:03 AM
mx127
Aug 10, 2015 08:13 AM
