Re-wiring 3rd gen
Old Jun 9, 2005 | 07:47 PM
BlackPearl's Avatar
Re-wiring 3rd gen
Hey guys, i am in need of some wiring help. The car i bought had started to be re-wired...it is a carbed 350...originally TBI 305... (92 RS)
Anyway, the guy ripped ALL of the wiring out...ALL of it...computer, harnesses ect...
I have a complete wiring harness for the car (fuse panel, some factory looking connectors, etc..)
My question is, will this new harness get me by? It has everything written on the wires (headlights, turn signals [L/R], brake lights, reverse lights, power windows, fuel pump, alternator, coil, etc...)
Do i need any of the stock wires? By that i mean, do i need any of the wires that originally went to the distributor, sensors on the motor, etc... I'm really hoping i didn't step into a nightmare...
Any help is appreciated...thanks a lot!
Here is a pic..>SORRY FOR THE SIZE!
Old Jun 9, 2005 | 09:44 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Resize your pics.
Old Jun 9, 2005 | 09:52 PM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
They make your post hard to read, and that kind of resolution is not necessary to show what you need to show.
Wow. You have your work cut out for you.
You said you have a complete wiring harness. What kind is it? The original one from the car? Aftermarket? Salvage from another F-body.
Basically, you will need everything that was in the original harness, except for the things that were either sensors read by the ecm, or devices controlled by the ecm. You will need wires to the distributor/ignition system, and the only sensors on the motor you will need are the ones for the gauges (oil press, coolant temp). Depending on what kind of carb you have, you may need an electric choke hookup.
Good Luck!!
Old Jun 10, 2005 | 10:54 AM
BlackPearl's Avatar
really sorry about the pictures guys, im at work right now, so i can't resize them...i'll do it tonight...my apologies...
Its an aftermarket wiring harness a lot like the painless wiring harness, but i dont think it is a painless i'll double check tonight...
So i need the connectors for the distributor etc... Damn, this isn't gonna be fun ...HAHAH!
ex-x-fire
Jan 12, 2024 01:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
