idle ?'s
Old Jun 9, 2005 | 07:48 PM
camaronick91's Avatar
Car: 91 z28
Engine: 350 stealthram
idle ?'s
i have a 91 z28 with a 350. i just did a tune-up cap and rotor and flamethrower ignition module. and i hook it a up the distrubuter was loosend and was adjusting something. if turn to far one way would die. i tried to get it a smooth as possible but after warmup the idle drops to 500 and will occasionly drop to 400 and seem like it almost wants to die. i tried crankin up the screw on the throttle body but didn't seem to help. i thought the timing was electronicly controolled or does the distrubter adjustment have to do with this. any help would be appericated.
Old Jun 13, 2005 | 08:23 PM
Car: 91 z28
problem fixed . had a 7ft vacuum hose the was rotted and now runs like a champ . idles and stays a 500.
Old Jun 13, 2005 | 08:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The advance is controlled by the computer, but the base timing is determined by the distributor position. You might want to check it now.
Old Jun 13, 2005 | 08:42 PM
Car: 91 z28
took it to the dealer and timing set to 6 deg. had nothing to do with the problem
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
