Wiring up a speedo
Old Jun 11, 2005 | 11:29 AM
Ironmahn's Avatar
Car: 1986 Trans Am
Wiring up a speedo
Not sure if this is the area to post this. Looking for some help or places to get information. I have a 1986 Trans Am came out with TPI 305, but when I purchased it 350 carburated. Through the years of miscellaneous owners the wiring harness has been cut to pieces i.e. plugs for a/c, & sending units gone(cut off) etc. Okay, I installed a different carburated engine with a 350 transmission and want to get the factory electronic speedometer to work; never has worked since I have owned it. Thanks for any help.
Old Jun 15, 2005 | 08:56 PM
Vader's Avatar
You need to install VSS in the tailshaft of the TH-350 (in place of the typical speedometer thimble) and wire it to the speedo head.
Old Jun 17, 2005 | 07:38 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
Also be aware that you might need a different tailshaft housing since the VSS needs the "big hole" (sorry for getting technical) version. My TH-350 had the "small hole" housing so I had to go the the junkyard to get the right one. Just something to look out for.
Old Jun 18, 2005 | 12:27 AM
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
This might help you http://la.rsson.com/speedo/speedo.html
I still have some of the stuff (VSS box etc) for sale if you need them drop me an e-mail jan_l@rsson.com
Old Jun 18, 2005 | 12:38 PM
Ironmahn's Avatar
Car: 1986 Trans Am
Thanks to all of you for the help.
Jorlain
Aug 24, 2022 05:11 PM
Jeremys87
Jul 14, 2022 09:08 PM
GTAman
Aug 27, 2015 10:29 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
beachrodder
Aug 7, 2015 04:27 PM
