Fuel Gauge Problem
Old Jun 13, 2005 | 02:02 PM
cuda71ss's Avatar
Car: 1986 Chevy Camaro
Engine: 5.7L 350
Fuel Gauge Problem
I am having trouble getting my fuel gauge to read right. I swapped in a carburated 350 in place of my 2.8 and now my fuel gauge is screwed up. What are the three posts for on the back of the gauge, ground, 12V, and a resistance wire to the sender? My gauge will either peg to its max or peg to its minimum dependent on how a hook up the wires. Any help would be greatly appreciated.
Old Jun 15, 2005 | 08:54 PM
Vader's Avatar
Ironic, perhaps, but OTC used to make a tester/simulator for thermal fuel guages. They may still.
The variable resistance connection is to the tank sender. Check the resistance of the tank level sender with an ohmmeter instead of connecting the guage. There should be between 0 and about 90 ohms from the sender to ground, depending on tank level (float position).
Old Jun 17, 2005 | 12:09 AM
cuda71ss's Avatar
Engine: 5.7L 350
The resistance read 3 ohms, but the peg is verticle and not pegged. Am I losing resistence somewhere?
Old Jun 20, 2005 | 08:23 PM
Vader's Avatar
You can simulate the float level sensor with a 100 ohm potentiometer. The problem is that it should be a 1W pot to handle the heater current of the guage. 3 Ohms may be correct depending on the fuel level in the tank.
You other choice is to replace either the guage or the float/sender in the tank to see if that's the problem, then possibly replace the other if you guessed wrong. A pot will be a lot cheaper than a float and guage, and certainly a lot easier to rig up as compared to dropping the tank.
Old Jun 21, 2005 | 09:26 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
Assuming there is a connection on the fuel tank sender wire, find it, and ground the gauge end of that wire. It should peg the gauge. If it doesn't, the problem exists "before" the tank. (wiring, gauge, etc) If it does peg, you've got a problem either in the sender, or the sender wiring.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
