Timing Issues PLEASE HELP
Car: 91 Camaro RS
Engine: 5.7
I just replaced my throttle body with a stock new one. I started up my car and the idol was very low. It was sitting at about 500 RPM. How should I reset the timing?
Idle RPM and tiiming are two entirely different things. Moreover, there's a good chance that one of the problems you are experiencing may be an incorrect TPS setting.
Perform a search for "TPS and Minimum Air Position" setting procedures. If you need to check timing, you can find lots of information on that by searching as well.
theshackle
Sep 17, 2020 08:26 AM
