Electronic connection cleaner?
Old Jun 11, 2005 | 12:19 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
I have seen this stuff in the store and heard it talked about a couple times on the boards. Does it do anything really? I have my ECM pulled out right know to check for a bad connection to the TPS should i buy some of this stuff and spray the ECM connections?
Old Jun 14, 2005 | 08:08 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
If you're asking which contact cleaner is good. If you need it, Caig's DeoxIT D5 is the beast I've used. Are you having problems with bad connections or just being safe?
Old Jun 14, 2005 | 06:11 PM
trueburton's Avatar
just keep having a code 21, Defectvie TPS or bad connection. And I've checked everything so it is kinda just for trial and error. I checked the connection and it looked clean so i jst put some dialectric grease on the connector.
Old Jun 16, 2005 | 04:51 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
How did you check the TPS?
Old Jun 21, 2005 | 06:02 PM
trueburton's Avatar
I checked each wire's voltage. THe one wire was like 4.9 volts, the ground showed good connection. and teh other wire was at .054.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
codeysabatini
Nov 10, 2015 04:07 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
gta892000
Sep 16, 2015 12:37 AM
edoff13
Sep 11, 2015 03:55 AM
