cold starts
Old Jun 22, 2005 | 10:13 PM
htrdss's Avatar
Car: 84 4x4, 86 iroc 67 chevelle
Engine: 350, 305 TPI, 327
Transmission: 4sp, auto, 4sp
cold starts
in the morning i have to crank the hell out of my 86 iroc tpi but once its warm starts fine
Old Jun 23, 2005 | 04:48 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Long crank time can be caused by a bad fuel pump relay. When you turn the key on, no crank, cold, have someone listen at the fuel tank for the 2 sec prime. Generally you hear a whine as the pump ramps up to speed. If you don't have prime what is happening is the oil sender unit has a sw inside for the fuel pump also-the pump has 2 sources of power. When you crank it cold the oil needs to get to 4-5 psi then the sw in the sender closes turning on the pump. Try cleaning the fuel pump relay socket and the relay pins with some contact cleaner, many times thats all it is. Welcome, Dan
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
