Electronical speedo
Old Jun 22, 2005 | 10:25 PM
Erick's Avatar
Car: Pontiac Trans-am GTA, model 1987
Engine: (L98) 350 tpi
Transmission: 4 speed automatic with overdrive
Electronical speedo
Can anyone tell me how the electronic speedo and the also electronic trip speedo works in the center dash panel of the 87 GTA?
Old Jun 26, 2005 | 11:16 AM
Vader's Avatar
The speedo head receives the current pulses from the VSS. Inside the speedo is a two-pole permanent magnet "motor" that converts the pulses to motion (much like a regular induction motor). This "motor" drives a magnetic coupling against a spring. The magnetic coupling is connected to the speedometer indicating pointer (the one that you see). The motor also drives the odometer, whose digits are stepped by the rotation and a ratchet/pawl mechanism. The trip odometer is simply mechanically linked to the cumulative odometer. This is why the electric speedometer and odometer will display speed and accumulate mileage in either direction (forward and reverse).
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
MrPackstin
Oct 25, 2017 08:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
anesthes
Sep 30, 2015 07:48 AM
