No parking lights, Fuse keeps blowing
Old Jun 27, 2005 | 08:33 AM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Ok, heres the story. On the way home from work one night, hit a decent sized bump. The tail fuse blew, and I lost parking lights and guage lights. Brake lights still worked and I believe turn signals still work. Changed the fuse when I got home and it seemed fine. The next day I got into the car to leave work, started it and turned on the lights. As soon as I turned on the lights it blew again. Ive even tried a 30A fuse and it continues to blow. I took the rear lights aparted and looked at the bulbs. The glass part on some of them were loose and falling out. Also, one of them had the filaments fused to the glass portion. Dont know if its coincidence or not, but I installed a new stereo amplifier that day. Anyone have any ideas?
Old Jun 27, 2005 | 08:56 PM
Notplayn's Avatar
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
Did you install a new radio or rewire the radio? The reason I ask is you mentioned a amp. If so, there is a wire behind the radio that is dark brown (looks black) that is sometime mistaken for a ground wire. It shows to be a ground until you turn the lights on, then it powers up and takes out the lights. (Dash, head/park light fuse and maybe some other things). Hope this helps..
Old Jun 27, 2005 | 11:06 PM
kcallais's Avatar
Car: 1985 Z28
Thanks for the reply. But no, the stereo has been in the car for a few months. However, now that you mention it, I did have to jam it in after I wired the remote turn on for the amp. Maybe I grounded something out. Ill check in the AM. Again, thanks!
Old Feb 20, 2009 | 01:04 PM
AKATDOG's Avatar
Car: 84 Z28
Re: No parking lights, Fuse keeps blowing
im having the same problem, what is this dark brown wire for ?
Ghettobird52
Jul 5, 2024 11:18 PM
LittleFranks
Sep 17, 2015 12:22 PM
Jk_Under
Sep 2, 2015 10:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
