AFS75 wiring...
Old Jul 5, 2005 | 07:39 PM
TWICEtheRICE's Avatar
Car: 91' Pontiac Firebird
Engine: 388 ci Small block CHEVY (4.060x3.75), Dart Iron Eagle Platinum 200cc, Performer intake, 454 TBI, Long Tubes, True Dual 3" GPs
Transmission: 700R4, B&M, Governer Recal, 20,000 GVW cooler
AFS75 wiring...
I bought a 4-wire ACDelco AFS75 Oxygen sensor.
I searched here and google, no luck
I am guessing the two wires with the same color are power put what is ground and signal?
Err, don't know the colors, I am at work now and in the morning I am wiring that all up.
Old Jul 6, 2005 | 11:48 AM
Okay, here are the actual colors in particular order:
Brown Brown Purple Tan
Old Jul 6, 2005 | 03:30 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Hope this helps. This should be the body side connector description.
Pin Letter:
Wire Color:
Circuit No.:
Function:
A
TAN
1667
Heated Oxygen Sensor (HO2S) - Low
B
PPL
1666
Heated Oxygen Sensor (HO2S) - High
C
BLK
150
Ground
D
BRN
241
Ignition (ON)
Blownz28man
Apr 2, 2015 08:28 PM
Cdeez
May 19, 2012 12:06 PM
BWilcox
May 25, 2010 12:01 PM
86z28iroc-z
Mar 14, 2008 02:26 PM
TWICEtheRICE
Jul 7, 2005 08:17 PM
