Alternator Question
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
Alternator Question
Im going to need to replace my alternator, I think it's 100 amps but I'm not sure. If I install a 140 amp alternator do I risk damaging the engine or electrical components?
In electronics class we were taught that Amperage is potential energy. By installing a larger one your only giving yourself more potential. The car should only pull however much power it needs.
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
you are right about that
also when you upgrade to larger amps, the cable should also be upgraded too
i put a 170 in her car
rock solid at idle with everything on and running.
i seriously recommend the CS140, higher output at idle over a cs130
Car: "02 z-28
Engine: LS-1
Re: Alternator Question
db057
Aug 11, 2015 10:11 PM
