Fuel pump relay wires?
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I want to try a kill switch but I don't know where the fuel pump relay wires run. Any tips where to find them under the dash? Thanks!
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Re: Fuel pump relay wires?
Pin "A" = a tan/white wire that goes to the fuel pump, the oil pressure switch, pin "E" of the MAF power relay, & pin "B2" of the ECM
Pin "B" = a black/white wire (ground) that goes to pin "A12" of the ECM and the back of the right cylinder head.
Pin "C" = a dark green wire that goes to pin "A1" of the ECM (fuel pump relay driver)
Pin "D" = a red/black wire that goes to terminal "G" of the ALDL (diagnostic connection) through connector C207.
Pin "E" = a orange wire that goes to pins "B1" & "C16" (power) and the 20 amp fuse by the battery.
