Using Stock TPI wiring harness...
Old Jul 14, 2005 | 09:21 PM
flowmasterchevy's Avatar
Car: '91 RS, F41
Transmission: WC T5
Ok im in the process of swapping my 79 malibu over to TPI. I am attempting to use the stock wiring harness. Has anyone ever done this? I would greatly appreciate a wiring diagram if anyone has one.
Old Jul 16, 2005 | 01:48 PM
Vader's Avatar
The stock harness should work well for the most part, but may require some alteration for the G-Body integration. It should plug right into the ECM from the TPI, and all the TPI engine sensors. You may have some issues at the ignition switch, brake switch, finding a VSS signal, fourth gear switch, and locating an ALDL in the old Chevy. Are you using an automatic with a TCC? EVAP canister? A.I.R. system and diverter? Air conditioning? EGR?
Jeremys87
Jul 14, 2022 09:08 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
marcusaw
Aug 10, 2015 08:13 AM
stalkier
Aug 7, 2015 04:49 AM
