shift lever with cruise control
Old Jul 16, 2005 | 08:41 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
I'm moving this thread here from body and interior, because the topic kind of branched off into a seperate discussion.
I have a 91 GTA and am trying to replace the shift lever (with cruise control).
Question 1: How do I get to the location of the plug for the controls? In the other thread, they said that the pad under the dash just drops down, and the new one should be there. This is not the case in my car. I just removed the pad, and the plug is definately located in the steering column. The wire coming off the shift lever isn't even long enough to reach that far down the column. So, how do I remove the plastic that is surronding the column? Please dont tell me the steering wheel needs to come off.
Question 2: How do I pull the old lever out? I was told it was just as simple of yanking it out. But elsewhere I was told I need to twist and pull.
Thanks for your time!
Bill
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
