fuel pump wires
Old Jul 24, 2005 | 11:46 AM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
fuel pump wires
can anyone send me wiring diagram on the fuel pump? I think ive got a hot wire grounding out somewhere but I have no idea where any of the wires are. Thanks in advance
Old Jul 24, 2005 | 12:50 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Your wires for the fuel pump come through the bulkhead behind the rear seats and run down the left side of the car underneath the door sill. The tan/white wire is the power wire, black is ground, and pink is the wire for the guages.
Old Jul 24, 2005 | 03:58 PM
Car: 89 Formula
Engine: 5.7 TPI
then whats the wire with the fuse on the driver side???
Old Jul 24, 2005 | 10:02 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Are you referring to the 20 AMP fuse in the engine compartment near the battery? If you are, that is a fuse for the protection of the ECM, fuel pump relay, MAF sensor & a couple of other items. If it is inside the car, then the previous owner did his own little kill switch modification.
Old Jul 25, 2005 | 04:38 PM
Car: 89 Formula
Engine: 5.7 TPI
yep its the one near the battery. damn thing, i drove it all day today, no problems...
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
