high amps at hiway speeds...
Old Aug 1, 2005 | 09:07 PM
silvernblack's Avatar
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
I have an ammeter in my car and a GM 12Si 94-amp alternator...
It can barelly maintain 11.8 vdc at idle (monitoring with Autoprom and a laptop). I can actually see that as the RPM goes up the battery voltage goes up to a steady 13.3 vdc.
I'm running fuel injection with a 730 ECM. Now, I suppose that there might be some heavier loading at speed, but my ammeter pegs at +40 when at full speed....doesn't look quite right.
Any ideas?
Old Aug 3, 2005 | 04:15 AM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
How old is the alternator?
Old Aug 3, 2005 | 06:57 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Voltage drop from overloading the ammeter maybe? FWIW they are totally useless to see how much the whole car is drawing. They are only useful when testing to see if something is working properly/checking why fuses are blowing.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
