110-145 MPH Gauge Cluster Swap
Old Aug 4, 2005 | 02:45 PM
Camaroz29's Avatar
Ok, I have a 91 Z28 with the 110 MPH cluster. My 145 MPH unit arrived today and I had previously asked about whether or not it was just a plug and play. I was told go ahead and just swap them out, but now my question is this: What about the odometer? My odometer reads 63k and the new one is like 173k. Is there a way to just swap one odometer to the other, and if so, isn't this borderline illegal?
Old Aug 4, 2005 | 03:00 PM
Muirner's Avatar
Car: 89 Camaro RS
Engine: 86 Monty 305 .030 over
i believe it is pretty illegal. while it is logical. best of luck, hell if your good u could roll it back
I do not suggest anything illegal just give ideas.
Muirner
Old Aug 4, 2005 | 03:04 PM
Camaroz29's Avatar
So if I want the 145 MPH cluster, the sacrifice I make is my odometer reading 173k? I don't think this is the case, because even that would be "altering" my odometer readout. This has to be a common swap, I just need to hear from someone who has done it.
Old Aug 6, 2005 | 09:18 PM
Camaroz29's Avatar
No one can help me with this? I know someone else has swapped to a better gauge cluster and didn't want an odometer with 3x the mileage on it?
Old Aug 6, 2005 | 09:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
On the mechanical units, you can swap the odometer rolls between the heads. You can probably do the same somehow on the electronic ones.
You can check with your local DMV on the legality of changing the odometer reading. For example, in some places you can do it as long as you put a sticker on the car showing what the old and new odometer readings were when the swap was made.
Old Sep 26, 2005 | 08:26 AM
ssean92's Avatar
Car: sold
just curious onse you get all this figured out could i buy your old 110 cluster?
Old Sep 26, 2005 | 08:46 AM
Camaroz29's Avatar
Sure, I think I figured it out. I found some places on the internet that'll set your odometers for you.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
