Want to wire my turn signals like a 98-up 4th gen
Old Jan 24, 2004 | 03:28 AM
86WS6_T/A's Avatar
Car: 2003 Mach 1
Ok, one thing I noticed on my moms car is that when the car is running / headlights on, the turn signals are bright.
If I'm right, the wiring on the 4th gen cars work like this: T/S is a dual filament bulb and both filaments are lit at all times. When the hazard / turn signal is applied, the bulb goes completely out then fully bright again.
For some reason, I think this just looks awesome and I want my turn signals to do this instead of just one filament being lit at all times and the second filament working the turn signal / hazard light function.
My idea is to wire both filament wires up to the constant hot (well, hot when the park/ headlights are on) and working some kind of reverse relay to the "second filament wire" so when power is supplied to this wire, it cuts power off at the other wire..
Now, I've never doen any wiring except a car alarm once and car stereo stuff. Does a relay like this even exist?
Thanks for any help anyone can provide
Old Jan 24, 2004 | 11:02 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The easy way would be to just pull the entire harness off of the later car and wire it up on your car.
Old Jan 24, 2004 | 04:25 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
Actually, I think it would be easier to splice two wires together and put a relay on that wire instead of trying to integrate 2 wiring harnesses together.
Old Sep 26, 2005 | 07:47 AM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
hmmm any one know what kind of relay would be needed
Old Sep 26, 2005 | 10:32 AM
85_ZED28's Avatar
Car: '85 Z28
https://www.thirdgen.org/techbb2/sho...&highlight=drl
Willie is the man to talk to
Caspar
Jun 19, 2016 11:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
Fronzizzle
Aug 9, 2015 01:15 PM
