Locked Keys In Car...need Help!
Old Sep 21, 2005 | 09:24 PM
MonteMan357's Avatar
Car: 1991 Z28
Engine: 357
Transmission: T-56 waiting to go in!
Axle/Gears: 3.73:1
Well stupid old me i locked my only set of keys in my car today. have no idea what i can do. I am leery of calling someone to slim jim it because i have no idea what the VATS system does or how it works. Help me guys what do i do? BTW its a 91 Z28 with power everything
Old Sep 21, 2005 | 09:54 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Slim jim it, retrieve your keys and sleep a little easier.
Power everything or power nothing.. VATS is simply related to the ignition and the car starting . It's not hooked to the locks or anything like that llike a car alarm would be.
Old Sep 22, 2005 | 04:03 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
Or if you still don't want to slim jim it you could always get a steel coat hanger or a long piece of steel wire (I personally have used a piece of filler wire for welding) And hit your button... that is if it is in the center console. Or if you have all the OEm stuff on the window you would be amazed at how far you can your window out... You can actually pull it out far enough to get a full set of keys to pass through it.. I have done so on 3 different f-body's so far. all third gen.
Old Sep 22, 2005 | 09:39 AM
Firebat's Avatar
after you get done with the slim jim, go get some spare keys made. At least your door key anyway. The VATS ignition key is expensive. I think a spare door key is a nice $5 or less investment.
Old Sep 22, 2005 | 01:46 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
welp i broke into my car today. took a 6 foot metal rod with me, grabbed hold of the pass side window and pulled out on it, stuck the rod in, hit the hatch release button and climbed in the back. Lesson learned....Getting spare key today
Old Sep 22, 2005 | 08:31 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Old Sep 23, 2005 | 08:34 AM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
Try pulling the window class, that helps me out whenever i lock my keys it, but it does leave a nasty bruise. And dont worry about the window being broken, u can pull for a certain amount.
Old Sep 23, 2005 | 08:49 AM
Icepack212's Avatar
Car: 1988 GTA
Engine: L98, mostly stock
I had to do this once, the problem is my hatch would not open unless the park. brake was on, so I had to pull the damn thing with a coat hangar and then push the hatch release with a long broom, hehe pain in the rear end.
Old Sep 23, 2005 | 08:55 AM
that is probably a safety feature.. to make sure you can not pop the hatch by accident when running down the road. never acutally thought to see if i had to pull the break in order for the hatch button to work...
Old Sep 23, 2005 | 02:04 PM
axeman's Avatar
Car: 84 HO Z/28 & 91 Z/28 Vert
Engine: 84 - 305 CARB 91 - 305 TPI
Transmission: 84 - 700r4
being a tow truck driver .....the slim jim is a pain in the *** to use on those cars ........but a good long wire is the best i can recommend for some one who doesn't have access to the tool designed for these cars........glad you got in though
Old Sep 23, 2005 | 02:09 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
yea i did it at my school (GVSU) and people walking by were looking at me all funny as i was sitting there with the 6 ft metal rod going through the window...kinda embarassing
Old Sep 24, 2005 | 02:04 PM
UCF1Slider's Avatar
Car: '89 RS Vert
Engine: LO3
I used a butter knife to pry my passenger side window out far enough to grab it with my hand. The window was flexible enough that I was able to stick my entire forearm into the car and press the unlock button on the door.
Old Sep 24, 2005 | 07:56 PM
stran63r's Avatar
Car: 1986 Camaro
Engine: 2.8
I use a wood paint stir that you can get at a hardware store. Just put it in on ht eleft side of the lock and push down, pops the lock every time.
Old Sep 26, 2005 | 11:58 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
If you have T-tops, breaking is easy. Just pry out one of your T-tops and open it. Than jump in like the doors were welded on. Its kinda fun.
Make sure you muscle everything back in once you are done, so no leaks occur .
I got stuck with the key in the car, and I got so pissed punched the car. Oooops, a dent!
Than once I got the keys back I cried
So, another lesson is...
If your car is not working right, and its frustrating, do not unleash your rage on it. Get a bag and...
Or suck up some helium and laugh.
Weed helps too
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
sahlomonic
Sep 20, 2015 07:15 PM
Denricci22
Sep 18, 2015 09:02 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
Gunsbee
Sep 7, 2015 07:10 PM
