Typical Altenator question
Old Aug 8, 2005 | 07:42 PM
jamessr's Avatar
Car: 92 Firebird
Engine: 5.0L V8
Transmission: 700-R4
My altenator at engine idle put out 14VDC, confirmed with a multi meter. However when I put on the AC and maybe power lights it will drop down as far as 12VDC, no more tho. Then when I step on the gas... with these accessories online, it will come back to 14VDC. Next stop light, 12VDC again.
Is this normal or should I trouble shot it?
Old Aug 8, 2005 | 10:40 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Never test any of my car's that did that . But I belive that is normal as long as I dose not drop below 12v and it gose back up with rpm . You are loading up the system with all that stuff on mostly the A/C not in a bad way . My little escort 4-banger barley move's with the A/C on , the defroster dose the same thing to it . Battery still going stong .
Frozer!!!
Jan 19, 2024 04:55 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Irocohio
Aug 12, 2015 08:03 AM
