ok what to do with some wires...
Old Aug 8, 2005 | 12:33 AM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
ok i have a 92 firebird that now has a 350 carb and a t56 trans that took place of a 3.1-t5. now can i remove the entire ecm?? im not sure because the vss for the trans runs thru the ecm doesnt it? i just need help bad. i dont have a/c or cruise anymore, or any smog so what to do.... thanx
Old Aug 8, 2005 | 01:04 AM
7plagues's Avatar
oh and what color are the water temp and oil pressure wires for the gauges to hook up to. i assume they come out of the drivers side.
Old Aug 8, 2005 | 01:53 PM
7plagues's Avatar
any help im lost on this
Old Aug 8, 2005 | 10:28 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
If you are running a HEI vacuum advance distributor you will not need the ecm .I belive you can seperate the vss from the harness not sure I have man hook up . If your motor is installed , Befor you start takeing stuff out get every thing goinng first . On my ride 85 Iroc carb I have a little canester in the back by the distributor , looks like a coil with a wier coming out the top . Thats my oil presser uint . As for the temp gage it is a dark green wier with a small flat conector that gose to the drive side head . If you ground it , it will peg the gage out . I hope some of this will help .
Old Aug 8, 2005 | 10:41 PM
7plagues's Avatar
thanks alot! what color is the oil pressure wire? about the vss i have a t56 in their and i was just wondering what to do? i have the dakota box. i read that i should un-cover all the vss wires all the way to the box and twist them so i dont get any static. does all that sound ok?
Old Aug 8, 2005 | 11:03 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
I can not call of the top of my head what color the oil press wier is , but it has a little boot on the end like a minni spark plug wier . I do not know about the vss , I would go with it if it comes from a reliable sorce . Good luck
88GTAbandit
May 27, 2005 11:54 PM
SBlackfoot
Aug 13, 2002 07:20 PM
Greg Kuhlmann
Sep 10, 2001 10:48 PM
