'89 Firebird side marker light bulb
Old Aug 11, 2005 | 01:38 AM
Jazz's Avatar
Car: '89 Firebird
Engine: 305ci V8 TBI LO3
Hi all,
Stupid question, but how do I change the bulb in my recently-acquired (and thoroughly awesome) '89 Firebird's passenger-side side marker light? There's no screws and it doesn't look like there's a way in from the inside... funny that the first thing that should flummox me on this car is something so small. The Haynes manual is also, sadly, of no use with this fix.
Any help would be appreciated!
Old Aug 11, 2005 | 11:08 AM
Firebat's Avatar
dont know if youre talking about the front or rear side marker light but here's advice for both.
Front- get underneath the car below the side light in front. reach up and twist the connector to the side light off. Should be about a 1/4 turn to twist off.
Rear- Take off the panel where the spare tire/jack are. Twist connector off.
Old Aug 11, 2005 | 11:10 PM
Jazz's Avatar
Car: '89 Firebird
Oops, it's the front one.
Thanks!
Old Aug 13, 2005 | 12:48 PM
Vader's Avatar
Depending upon the ground effects installed, you may have to remove the fasteners from teh outer baffle and flex it downward slightly to get better access to the lamp housing.
Grab some 194 lamps for replacements.
Old Aug 14, 2005 | 02:10 PM
Jazz's Avatar
Car: '89 Firebird
Figured it out. And yesterday, it needed a headlight replacing (which thankfully was nice and easy). Funny, I've had to replace four different lights - three bulbs and the sealed headlight unit - on the car in the two months or so I've had it... other than that, I'm loving the car and still using every excuse I can think of to drive it.
Although now the oil pressure gauge doesn't want to work. D'oh!
Fronzizzle
Aug 19, 2015 01:36 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
