TA headlights go up... dont go down.
Old Aug 28, 2005 | 05:37 PM
lunatic_magnet's Avatar
Car: 87 camaro
Transmission: 5-speed
the headlights go up on my gf's 89 ta but they do not go back down. both started doing this at the same time...
i thought it might be the headlight control relay, so i replaced it and they still don't work. i've also replaced the switch in the dash and that did not fix the problem either.
if one headlight needs a 'rebuild' will it cause both not to go up/down?
Old Aug 28, 2005 | 08:59 PM
ejm's Avatar
ejm
Car: 83 Black T- top Firebird
Engine: Carbed 350
Transmission: 5 speed
Mine went up but not down because a fuse was blown. Not excatly sure what one it was because I had to replace a bunch.
Old Aug 29, 2005 | 12:42 AM
Firebat's Avatar
Re: TA headlights go up... dont go down.
i dont think it would be the cause. As ejm says - check your fuses.
Old Aug 29, 2005 | 03:22 AM
Car: 87 camaro
all fuses appear to be good... that was the first thing i checked.
Old Sep 2, 2005 | 08:35 AM
mopain's Avatar
Car: 1986 trans am
Engine: 305 tpi
Transmission: th700r4
if your car is like my 86 ta, there are 3 relays in the system. 2 of them controle only one headlight motor and the other relay works both of your headlights. if there is a short in your headlight isolation relay(i think thats what is called) it could cause your lights to do that.
i was not able to find the right relay for it, even from the dealer. i just hooked up a 3 way toggle switch to my lights. now they both go up and down fine. i know it's kinda ghetto, but it beats popping the hood and dong it manually.
Old Sep 3, 2005 | 10:27 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I just got a 85 TA (Im a camaro guy)
Lights worked fine since I got the car. Now all of a sudden lastnight they wont go up. They come on but wont pop up now. They do go down.
Where are these 3 relays for the system?
Old Sep 3, 2005 | 11:23 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There are three relays as mentioned. There is a relay on the left hand fender behind the left headlight, another one behind the right hand headlight on the left side of it. The third relay is the isolation relay, it is located behind the right hand headlight.
Old Sep 3, 2005 | 01:56 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Correct information for 1982-86 Firebirds. However the 1987-92 Firebirds have a completely different haeadlamp motor system with only one relay which controls the motors. That relay is located on the firewall between the power brake booster and wiper motor. It is called the headlamp control module and has "GUIDE" molded on the cover.
Lon
Old Sep 3, 2005 | 10:22 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
His car is an 85 T/A that I was responding to.
Old Sep 4, 2005 | 12:51 AM
lonsal's Avatar
And the original person posting has a 89. Don't you hate it when a thread has been hijacked? I just think it is important to keep reminding everyone of the differences in the two headlight actuator systems. So often (as in this thread) I'll see someone with a 82-86 relating how they resolved the problem on their car to someone with a 87-92. The two are different and require different solutions.
Lon
Old Sep 4, 2005 | 06:42 AM
Car: 87 camaro
...speaking of which, i still have not found the problem.
Ed1LE
Sep 30, 2018 09:14 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
