charging system question
Old Sep 1, 2005 | 12:07 PM
mopain's Avatar
Car: 1986 trans am
Engine: 305 tpi
Transmission: th700r4
let me ask yall a question. in the morning when my car is cool my votage gauge reads about 14 volts. after the car is warmed up the voltage gauge drops to about 11-12 volts. i've checked the output at my alternator and it is fine. also when i turn on any lights the voltage gauge drops. when i turn on my blinkers the gauge bounces with the blinkers.
so is this normal or is there a problem somewhere?
Old Sep 1, 2005 | 09:52 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes that is pretty normal, if you had a bigger drop than that then I would worry about it.
Old Sep 2, 2005 | 08:23 AM
mopain's Avatar
Car: 1986 trans am
Engine: 305 tpi
thanks for your reply. i don't really understand why it does this. but as ling as it is not a problem, i guess i wont be concerned.
Old Sep 4, 2005 | 08:38 PM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
well untill your car warms up your rpms are a lil higher (around 1000) and the alt in return spins faster. then it warms up and it drops to between 500-750 and the alt slows down. also the more acc. your runnin the more drain its puttin on the batt. and the alt if not spinnin quick cant fully keep it charged but its a normal thing.
Old Sep 4, 2005 | 09:06 PM
Vader's Avatar
It has something to do with rules devised by a guy named Ohm, and another guy named Voltaire.
Old Sep 5, 2005 | 09:48 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
similar to the reason when you put a 10 amp charger on your battery it reads 10 amps when you first connect it, but only reads 6 amps in the morning. I have no idea what that reason is, but its probably related.
mine does the same thing, so its no biggie.
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
